05-28-2024 02:58 PM
I have Lennar Ruckus system installed. I am getting Intermittent and slow connection, some device working and some taking forever to load connection. sometime i am getting socket error. Please suggest how can i fix?
i got switch and access points installed in my home from Ruckus
05-29-2024 06:26 AM
Hi @mp2025
As per the case description, I understand that your RUCKUS setup is not working with Intermittent Internet connectivity.
Please let us know the answers to the below queries to assist you better.
3. Is your Internet Connection from the Internet Service Provider (ISP) stable and working? (You could check this by connecting to your local router Wi-Fi or from an ethernet cable from the Router to a laptop/PC).
Please let me know the answers to ALL the above queries and let me know if you have any queries in this regard.
05-30-2024 06:28 AM - edited 05-30-2024 06:29 AM
Its not new installation.
Yes it was and i was out of country. I believe there was power outage and when I came back it was having slowness and intermittent connection. Some device working for some time. And some were not able to connect if connect then work very slow.
All lights are green
Yes its stable only issue if I connect with AP
3 AP installed in my home
AP1
AP2
AP3
Mukul
05-30-2024 07:13 AM
Hi @mp2025
As per the pictures you shared, your RUCKUS ICX-7150-C12P Switch and Access Points are in normal state.
After reviewing the case description, it appears that this problem may stem from a routing code issue on the RUCKUS ICX-7150-C12P Switch, particularly following a power outage.
To assist you in resolving this matter, I recommend consulting the RUCKUS Lennar Knowledge Base, where we have provided a self-help article addressing this specific issue. You can access the article via the following link:
Please proceed with the steps outlined in the article, and do not hesitate to reach out should you encounter any difficulties along the way.
Thank you once again for your patience and cooperation in this matter.
05-30-2024 09:05 AM
I tried to connect switch but did not get access remotely or usb-c. Please suggest?
mp@ms-mbp ~ % ssh [email protected]
ssh: connect to host 192.168.0.210 port 22: Connection refused
ping 192.168.0.210
PING 192.168.0.210 (192.168.0.210): 56 data bytes
64 bytes from 192.168.0.210: icmp_seq=0 ttl=64 time=15.030 ms
64 bytes from 192.168.0.210: icmp_seq=1 ttl=64 time=2.834 ms
64 bytes from 192.168.0.210: icmp_seq=2 ttl=64 time=4.670 ms
64 bytes from 192.168.0.210: icmp_seq=3 ttl=64 time=4.417 ms
64 bytes from 192.168.0.210: icmp_seq=4 ttl=64 time=6.723 ms
^C
--- 192.168.0.210 ping statistics ---
5 packets transmitted, 5 packets received, 0.0% packet loss
round-trip min/avg/max/stddev = 2.834/6.735/15.030/4.328 ms
