โ06-29-2023 09:01 PM
Hello, I have a ICX 7150 that has not been working, I have followed all console connection settings to hit a "failed ping" message...I was wondering what else could I possibly do, or what pictures/proof do I need to provide for a replacement device.
This community has helped me tremendously with all the possible troubleshooting steps, the techs are responsive and this forum is extremely valuable...however I have hit a brick wall.
Thank you in advance
โ06-30-2023 07:01 AM
Hi Clement
Thank you for reaching us
Could you please let us know if you are from Lennar Homes ?
Could you please help us with more details about the issue you are seeing ?
Are you seeing any amber LED in front panel of the switch ? Please upload picture from front panel of the switch.
You can upload pictures about the error you are seeing or issue with specific connections using the below option.
โ06-30-2023 12:40 PM
Yes, I have a Lennar home and a connection issue started almost 6-7 months after we purchased. The switch showed the amber system light and the green power light. Our APs didn't have any power or ethernet. I was called up to a military obligation across the water for almost a year so I am just now able to try and figure out our internet issues. After factory resetting the lights now blink amber over and over.
โ07-02-2023 02:17 PM
This this post get bumped? I have followed all troubleshooting steps and downloaded the driverโฆbut I could not install it because I couldnโt connect to the switch
โ07-03-2023 05:08 PM
Hi @Clement
Hope you are doing well!!!
Apologies for the delayed response.
As per the case description, I could understand that your RUCKUS setup is not working, and Switch has Amber lights flashing after trying reset.
Basically, due to the power outage/power spike, the switch went to a state that we call โboot modeโ that is not able to boot up properly.
As you mentioned that you tried reset, once again we will try to reset the Switch as described below:
IF RESET IS NOT WORKING, PLEASE TRY TO RESET YOUR SWITCH MULTIPLE TIMES (Like 10-15 times) AS DESCRIBED ABOVE.
IF RESET DOESNโT WORK: Please follow the below steps.
