06-29-2024 04:09 PM
The lights on the u it flash one time when plug in and then hose dark with no activity. I have tried resetting it the plugging it into multiple different outlets and using different cords with no charge in it’s activity. I believe it needs to be replaced. Please help
07-24-2024 05:42 AM
Dear @Zakee83
Thank you for your prompt response and the update provided.
Could you kindly share your email address with me, the one through which you sent the video?
I appreciate your patience and understanding in this matter.
07-24-2024 07:28 PM
Zakee83@gmail.com
07-25-2024 05:35 AM
Hi @Zakee83
Greetings of the day!!!
Thank you for sharing the requested PICTURES and a VIDEO.
Based on the troubleshooting done, your ICX-7150-C12P Switch is not powering up, and when plugged in, it flashes an amber light and then goes dark. And you confirm that the Switch is plugged into a well-known outlet/power source. However, the failure persists. This Switch unit Should be RMA (Return Merchandise Authorization) in simple words replacing it.
07-02-2024 02:45 PM
Hello @Zakee83 ,
07-04-2024 07:11 AM
Hello @Zakee83 ,
