05-31-2025 08:59 AM
I purchased a Lennar home. The previous owner left the ruckus boxes but did not provide any information on how the smart home works. I called Lennar and they said they no longer deal with this? I have 2 Ruckus Unleashed 510 series, one per floor on the ceilings. My AT&T fiber comes in downstairs and there is a box on the wall upstairs with the Ruckus main hub. When I moved in, the box downstairs had a couple of wires (ethernet) but they recently replaced my modem and removed that box and replaced it with a wall plate with one fiber wire that connects to the BWG 320 modem. On the main Ruckus box upstairs, there are 2 lines labeled WAP that are connected (light beside upstairs WAP is green, no light by downstairs) as well as a line labeled Ethernet from AT&T (no light showing?). There are 3 other lines connected (showing green) labeled Samsung hub, Lutron Bridge, and Kevo Bridge. The only lights showing on the 510s upstairs and downstairs are power and ctl (blinking). I installed the app but it doesn’t “see” a ruckus device. I downloaded the Fing app but it doesn’t show a Ruckus device. I tried to logon to the website recommended to locate the AP address but it said server not working. Help? I have no idea how to connect the two 510s? When they switched the box downstairs, did it disconnect the ethernet to the main ruckus box upstairs?
06-18-2025 08:00 AM
So it looks like I have to purchase two more cables if I can make them out from the video. I’ll get back to you once I have them.
06-18-2025 09:07 AM - edited 06-19-2025 06:51 AM
Hello @Andrea ,
We will keep the case open until we have an update from you.
07-04-2025 09:37 AM
Hello @Andrea ,
07-07-2025 07:33 AM
Hello @Andrea ,
07-14-2025 07:52 AM
Hi @Andrea ,
Thank you.
