05-31-2025 08:59 AM
I purchased a Lennar home. The previous owner left the ruckus boxes but did not provide any information on how the smart home works. I called Lennar and they said they no longer deal with this? I have 2 Ruckus Unleashed 510 series, one per floor on the ceilings. My AT&T fiber comes in downstairs and there is a box on the wall upstairs with the Ruckus main hub. When I moved in, the box downstairs had a couple of wires (ethernet) but they recently replaced my modem and removed that box and replaced it with a wall plate with one fiber wire that connects to the BWG 320 modem. On the main Ruckus box upstairs, there are 2 lines labeled WAP that are connected (light beside upstairs WAP is green, no light by downstairs) as well as a line labeled Ethernet from AT&T (no light showing?). There are 3 other lines connected (showing green) labeled Samsung hub, Lutron Bridge, and Kevo Bridge. The only lights showing on the 510s upstairs and downstairs are power and ctl (blinking). I installed the app but it doesn’t “see” a ruckus device. I downloaded the Fing app but it doesn’t show a Ruckus device. I tried to logon to the website recommended to locate the AP address but it said server not working. Help? I have no idea how to connect the two 510s? When they switched the box downstairs, did it disconnect the ethernet to the main ruckus box upstairs?
06-04-2025 10:21 AM
Hello @Andrea ,
We really appreciate you arranging a Windows laptop in troubleshooting the issue.
Please let us know once you have access, and we’ll be happy to proceed from there.
06-17-2025 06:08 AM
I think I have the wrong cable? I purchased a type C to RJ45 but I’m using a Mac with Windows?
06-17-2025 07:03 AM
Hello @Andrea ,
The cable should be a type C to USB connector as shown in the below figure
Could you please share a picture of the cable connections between Switch and laptop?
06-17-2025 11:01 AM
The MAC computer requires a type “C” connection. It does not have a USB. According to your diagram there are two console ports # 1. Type C and # 15. The RJ-45. The console cable I purchased is a Type C and RJ-45. Can I use this cable with my Mac? Will the Putty/MobaXterm work if I’m not using a USB?
06-17-2025 02:09 PM
Hello @Andrea ,
Thank you for your response.
I understand that you are using a cable with a Type-C to RJ-45 connector.
You may utilize an external adapter to connect the cable from the Switch to your Mac laptop.
To assist with obtaining console access on a Mac, please refer to the following video:
Video on Console Access for Mac
