03-27-2024 02:52 PM
moved into a pre owned lennar home. Need help setting this up.
I have ATT and ran a cat-7 wire from the back of the router to port 3 on the rockus switch. The rockus switch has a cat-5 or 6 wire connected to the access point. It connects and works, but its extremely slow. I checked directly on the ATT router and i get a Gig speed, but when connecting on the access point i get about 25Mpbs which is super slow.
Need help, and also if there is a installation guide you can send me. I would like to update the switch and access point as well at some point.
03-29-2024 06:41 AM
Hello @parrillas
Please check the articles below:
Admin usernames and passwords for the Ruckus Wi-Fi Access Points/Switch for Lennar home users:
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/Admin-usernames-and-password...
Physical Factory Reset an Access Points Ruckus:
https://community.ruckuswireless.com/t5/RUCKUS-Support-for-Lennar-Homes/Ruckus-Unleashed-Set-up-usin...
Feel free to contact me if you have questions.
Kind regards,
Sofia Gätjens
03-31-2024 12:55 AM
I got it to work and access point firmware has been updated. Im not able to get the switch updated and the internet is very slow. Is there someone that can call me or send me a replacement switch. This is very inconvenient and i already wasted a week dealing with this.
04-01-2024 05:50 AM
Hi @parrillas
As per the case description, I understand that you need assistance in setting up your RUCKUS devices.
Apologies, as per the company policies we cannot replace the Switch since this is a software issue that can be fixed following the troubleshooting steps. Please do not worry I will help you set this up.
Please refer to the short guide link below about how to connect the devices as a reference: Make sure to connect your device as per the below pictures and guide.
Once you confirm it connection as per the guide, please let me know the answers to the below queries to assist you better.
2. Is your Internet Connection from the Internet Service Provider (ISP) stable and working? (You could check this by connecting to your local router Wi-Fi or from an ethernet cable from the Router to a laptop/PC).
3. May I know how many Access Points are connected to the Switch? Could you please let me know the light status on the Access Points? Any of these lights are on (Please refer to the below picture and share a picture of the same)
Please let me know the answers to ALL the above queries and let me know if you have any queries in this regard.
04-01-2024 12:50 PM
