Firmware Upgrade for ICX7150-C12 Switch - Need help locating Firmware version and help upgrading
MiSNemesis
I have a ICX 7150 since 2020 and was never upgraded.  I am at a lost as to how to locate the version and then what upgrade is necessary to use.  Any help would be appreciated.
1 ACCEPTED SOLUTION
Valued Contributor III
Hi @MiSNemesis
The recommended firmware version for ICX 7150 Switch is SPS08095dufi.bin
Please follow the below guides to perform an upgrade to the code 08095g UFI and upgrade both partitions with the switching code file named SPS08095gufi.bin to avoid the issues in future.
36 REPLIES 36
MiSNemesis
08.0.90BT211 (SPS08090d.bin) - I found this Compressed Pri Code version.  This was under Compressed Sec Code 08.0.90BT213 (SPR08090d.bin)
MiSNemesis
Hi @MiSNemesis
SSH@ICX7150-C12 Switch#show ver
UNIT 1: compiled on Sep 22 2019 at 23:54:26 labeled as SPS08090d
(28660224 bytes) from Primary SPS08090d.bin (Non-UFI)
SW: Version 08.0.90dT211
Compressed Primary Boot Code size = 786944, Version:10.1.15T225 (mnz10115)
Compiled on Thu Jan 31 03:08:55 2019
HW: Stackable ICX7150-C12-POE
UNIT 1: SL 1: ICX7150-C12-2X10GR POE 12-port Management Module
Serial #:FEK3203P15K
Current License: 2X10GR
8192 KB boot flash memory
2048 MB code flash memory
1024 MB DRAM
STACKID 1 system uptime is 121 day(s) 20 hour(s) 55 minute(s) 13 second(s)
The system started at 06:39:31 GMT-05 Sat Mar 11 2023
=============== WARNING: FI image is not booted from UFI!!! ========= ======
====== Please download UFI image and reboot the system for full functionality ======
Not sure what to do here now.
