02-28-2024 10:37 AM
No internet or wifi starting 3 AM this morning. I unplugged the Ruckus ICX-7150-C12P and am able to connect hardwired to the internet. If I plug it back in I lose the hardwired connection and still no wifi.
03-04-2024 04:21 AM
HI @BillRamos
Could you please let me know to which port on the Switch, ethernet cable coming from ISP (Internet Service Provider) is plugged? (Please refer to the below screenshot)
Please confirm and let me know if you have any queries in this regard.
03-04-2024 04:52 AM
I am guessing where the blue cable from the router to the Ruckus went as I've had it unplugged all this time so I can maintain my hardwired connections from the router.
The white cables from the router are the hardwire connections to other parts of the house. As an aside, should those also be plugged into the Ruckus so that the only thing connected to the router are the Ruckus and Modem cables?
Modem
Router
Ruckus
03-04-2024 05:03 AM
Hi @BillRamos
As I see from the picture you shared, the ethernet cable which is coming from the ISP’s (Internet Service Provider’s) Router or Modem/Router combo is plugged into the wrong port on the Switch panel. It must be plugged into any 1 in-12 ports as shown in the below screenshot. Please unplug the ethernet cable and plug it into the correct port and Reboot (Unplug and plug from the power outlet) your ISP Router and RUCKUS ICX-7150-C12P Switch once.
Please try to connect to the Internet after the above process and let me know if you have any queries in this regard.
03-04-2024 06:16 AM
I am doing that now. I want to make sure everything is set up the best way possible so should also have the other (white) ethernet cables connected to the Ruckus rather than the ISPs router?
03-04-2024 06:58 AM
Hi @BillRamos
No, the connection must be from the Modem>>Router>> RUCKUS ICX-7150-C12P Switch OR Modem-Router Combo>> RUCKUS ICX-7150-C12P.
Just plug the cable coming from the Router on the correct port of the Switch and reboot as described in my previous post.
