07-27-2024 01:49 PM
I want to preface this with I do not speak technology.
Yesterday we had a contractor in our home who tripped a breaker that our ruckus was on. The power to the ruckus was only out for about 10 minutes, but when it got turned back on our Wi-Fi Internet has been spotty. Our Google speakers cannot connect and our ring keeps losing connection and regaining connection within the same 60 seconds every couple hours.
We tried to reset it but it was unsuccessful. We don’t know the actual problem, but we also don’t know enough to research the right answer.
Can anyone help?
We have lost power before but we have never had an issue like this with the ruckus.
TIA
07-29-2024 07:32 AM
Hello @Kerickson516,
From the case description, I understand that your Ruckus setup is not working after the power outage.
Could you please let us know the answers to the below queries to assist you better.
2. May I please know how many Access points are connected to the Switch and if all the Access points are not turning on?
Please help us with pictures of your ICX-7150-C12P Switch showing the status of the lights and cable connections to the Switch ports. Please share the status lights of the Access points too.
Before uploading the photos, please log in to the RUCKUS account and you can upload the image.
07-29-2024 08:18 AM
Thank you for your reply.
Hopefully the attached is what you are looking for.
There are two access points connected to the Ruckus. Their lights are all green - every once in awhile the 5g will turn amber but then flip back to green.
07-29-2024 10:14 AM
Hi @Kerickson516 ,
As per the light status I see from your screen shot, I see that the lights are in the normal state and we need to check few switch configuration details to understand the issue better and assist you further.
ICX7150-C12 Router> OR
ICX7150-C12 Switch>
show version
show flash
07-29-2024 12:50 PM
I can't seem to run Putty successfully, it keeps saying Network Error: Connection timed out
