02-15-2023 03:45 PM
I live in a 55+ community in Fredericksburg VA. When we first moved in (2021), we had Ruckus connectivity issues and a technician (at that time) replaced on of the two units we have. A year later, I'm still having connectivity issues, where the signal strength will "disappear" and then come back. I bought a range extender in hopes of helping the signal to limited success. I called customer service recently and was told I could no longer speak to a live person for assistance if I owned a Lennar home and to come to this forum for assistance, so here I am. How can I rectify this issue and is there a live person available to speak to or even come out to my home to troubleshoot the issue(s)?
Sidenote: When I was last able to speak to someone, I was told that a switch would most likely needed to be changed in the future. The tech referenced switch, ICX 7150-C12
02-15-2023 03:59 PM
Hi ML22
Hope you are doing well!!!
Apologies for any inconvenience caused.
Effective November’2022, ‘Ruckus Support for Lennar Homes customers will no longer be handled by phone or email. We will be exclusively supporting customers via this community forum support model.
From the case description, I could understand that you have connectivity issues, where the Signal strength and connectivity issues.
This issue may happen when the Switch runs on the Routing code. The Switch should run on the Switching code to avoid these issues for Lennar home users. If the Switch boots up on the other partition (Due to a power outage may be) which may be running on a ‘Routing Code’ results in causing this issue.
You can take Console access to the switch in order to verify, if the switch is able to connect properly to Access Points or if it has a ‘Routing Code’ issue which happens due to power outages most of the time, this is a known issue for Lennar home users.
-MAC address: Physical address of the device this never changes
- An IP address is a unique address (logical) that identifies a device on the internet or a local network like your home (this can change and may not be the same as the one shown on the dashboard)
Please follow the below steps:
ICX7150-C12 Router>
show version
copy flash flash secondary
(Please share the output screenshot of the ‘show version’ command)
Example:
There are Two ways to fix this issue:
I) How to Fix Routing code issues on Lennar Home users via CLI
II) Or WEB access option
Once you are logged in to the ICX-7150-C12P please follow up the same steps that are on point '3'
Please do let us know if there is any help required on the troubleshooting steps or if you are stuck at any point. We are happy to help you.
Lennar Home Community.
