Connectivity issue with RUCKUS
Jyothik16
I have been using RUCKUS for more than three years and never had a any issues. Past from few days I challenges to access Internet through RUCKUS
appreciate if you could help me to resolve this.
Jyothi
2 ACCEPTED SOLUTIONS
Hi @Jyothik16
This issue is because your switch is running on the Routing code (SPR). The Switch should run on the Switching code (SPS) to avoid these issues for Lennar home users. Due to a power outage/power spike, the Switch boots up on the other partition which may be running on a ‘Routing Code’ results in causing this issue.
As I can see from the output you shared, your Switch is booted up on the secondary partition which is running on Routing code (SPR) as highlighted in the below screenshot.
copy flash flash secondary
Example:
VIDEO LINK AS REFERENCEhttps://www.youtube.com/watch?v=Eem1IBgYaWc
We suggest upgrading your switch to the latest stable version to avoid this issue in the future. Your Switch is on an older version that is 08080d. Please let us know once you complete the above process to assist you with the Upgrade of the Switch.
Seems like it’s stable. In the morning when I looked at RUCKUS upstairs it showed all red lights but now it doesn’t.
Thank you for all you timely response and guidance to resolve the issue.
Jyothi
34 REPLIES 34
Jyothik16
Hello Chandini,
still issues isn’t resolved. Internet is not working if I am using through RUCKUS but it does work through my internet provider.
i would appreciate if you could provide solution and guidance to resolve the issue.
jyothi
admin test
Hi @Jyothik16
Hope you are doing well!!!
As per the case description, I could understand that your RUCKUS setup is not working from somedays.
Could you please let me know if you started facing this issue after you tried to Upgrade your RUCKUS Unleashed system from Web portal?
Please confirm and let me know if you have any queries in this regard.
I was having issue before upgrading the RUCKUS from online. I was trying to resolve the issue and thought by upgrading RUCKUS would help to get the internet issue resolved but it didn’t happen.
Hi @Jyothik16
1. On your switch while it's plugged into the outlet, do you see any lights on? (Amber or green) Please let us know which lights are on. (Please refer to the below picture and share a picture of the same, showing the light status and the FULL Switch panel cable connections to the Switch ports)
2. Is your Internet Connection from the Internet Service Provider (ISP) stable and working? (You could check this by connecting to your local router Wi-Fi or from an ethernet cable from the Router to a laptop/PC).
3. May I know how many Access Points are connected to the Switch? Could you please let me know the light status on the Access Points? Any of these lights are on (Please refer to the below picture and share a picture of the same)
