Both AP's Power off.
ariark
Hi, our access point's (AP) has been experiencing frequent power off's. Every time my ICX 7150 C12 switch need manually power off and power back on after AP's power on. I reset my both AP and getting same issue. Please help to resolve issue.Before power cycle with no active AP'sBefore power cycle with no active AP'sAfter power recycle with active AP'sAfter power recycle with active AP's
17 REPLIES 17
ariark
ICX7150-C12 Switch>enable
ICX7150-C12 Switch#show version
Copyright (c) 1996-2017 Brocade Communications Systems, Inc. All rights reserv ed.
UNIT 1: compiled on Aug 14 2017 at 06:54:44 labeled as SPS08061a
(24723488 bytes) from Primary SPS08061a.bin
SW: Version 08.0.61aT211
Compressed Boot-Monitor Image size = 786944, Version:10.1.10T225 (mnz10110 )
Compiled on Sun Jun 25 09:25:15 2017
HW: Stackable ICX7150-C12-POE
Serial #:FEK3236N0EA
Current License: 2X1G
8192 KB boot flash memory
2048 MB code flash memory
1024 MB DRAM
STACKID 1 system uptime is 7 hour(s) 55 minute(s) 58 second(s)
--More--, next page: Space, next line: Return key, quit: Control-c^C
ICX7150-C12 Switch#show flash
Stack unit 1:
Compressed Pri Code size = 24723488, Version:08.0.61aT211 (SPS08061a.bin)
Compressed Sec Code size = 28314668, Version:08.0.61aT213 (SPR08061a.bin)
Code Flash Free Space = 1311735808
ICX7150-C12 Switch#^C
ICX7150-C12 Switch#
pinky_ruckus
Valued Contributor III
Hello @ariark ,
From the response you shared, I see that the Switch is on an older version 08061a.
We suggest upgrading your switch to the latest recommended version to avoid this issue in the future.
Please follow the below RUCKUS Lennar Knowledge base self-help article which will help you to upgrade the switch to the recommended version.
Please follow the process explained in the article and let me know if you have any queries in this regard.
Hi i am getting same error continues in the middle firmware update. I restarted the switch and still same error getting
PoE Fatal: Vmain (48V) fault has forced all ports on slot 0 to lose power.
Thank you.
pinky_ruckus
Hello @ariark ,
Could you please confirm if the Upgrade was performed on the Switch?
show version
show flash
show inline power
show inline power detail
show interface brief
Compressed Boot-Monitor Image size = 786944, Version:10.1.14T225 (mnz10114 )
Compiled on Thu Nov 15 12:59:22 2018
1024 MB DRAM
STACKID 1 system uptime is 2 hour(s) 32 minute(s) 57 second(s)
Stack unit 1:
Compressed Sec Code size = 25976488, Version:08.0.80fT211 (SPS08080f.bin)
Code Flash Free Space = 1311367168
ICX7150-C12 Switch#show inline power
Power Capacity: Total is 124000 mWatts. Current Free is 93200 mWatts.
Power Allocations: Requests Honored 4 times
1/1/1 On On 3400 15400 Legacy Class 3 3 n/a
1/1/2 On Non-PD 0 0 n/a n/a 3 n/a
1/1/3 On On 3400 15400 Legacy Class 3 3 n/a
1/1/4 On Off 0 0 n/a n/a 3 n/a
1/1/5 On Non-PD 0 0 n/a n/a 3 n/a
1/1/6 On Off 0 0 n/a n/a 3 n/a
1/1/7 Off Off 0 0 n/a n/a 3 n/a
1/1/8 Off Off 0 0 n/a n/a 3 n/a
1/1/9 Off Off 0 0 n/a n/a 3 n/a
1/1/10 Off Off 0 0 n/a n/a 3 n/a
1/1/11 Off Off 0 0 n/a n/a 3 n/a
1/1/12 Off Off 0 0 n/a n/a 3 n/a
Total 6800 30800
ICX7150-C12 Switch#show inline power detail
Power Supply Data On unit 1:
Power Supply Data:
Power Supply #1:
Max Curr: 2.3 Amps
Voltage: 54.0 Volts
Capacity: 124 Watts
PoePower: 124 Watts
POE Details Info. On Unit 1 :
General PoE Data:
ICX7150-C12 Switch#show interface brief
Port Link State Dupl Speed Trunk Tag Pvid Pri MAC Name
1/1/1 Up Forward Full 1G None No 1 0 78a6.e12e.d2e0
1/1/2 Up Forward Full 100M None No 1 0 78a6.e12e.d2e1
1/1/3 Up Forward Full 1G None No 1 0 78a6.e12e.d2e2
1/1/4 Down None None None None No 1 0 78a6.e12e.d2e3
1/1/5 Up Forward Full 1G None No 1 0 78a6.e12e.d2e4
1/1/6 Down None None None None No 1 0 78a6.e12e.d2e5
1/1/7 Down None None None None No 1 0 78a6.e12e.d2e6
1/1/8 Up Forward Full 100M None No 1 0 78a6.e12e.d2e7
1/1/9 Down None None None None No 1 0 78a6.e12e.d2e8
1/1/10 Up Forward Full 100M None No 1 0 78a6.e12e.d2e9
1/1/11 Up Forward Full 10M None No 1 0 78a6.e12e.d2ea
1/1/12 Up Forward Full 1G None No 1 0 78a6.e12e.d2eb
1/2/1 Down None None None None No 1 0 78a6.e12e.d2ed
1/2/2 Down None None None None No 1 0 78a6.e12e.d2ee
1/3/1 Down None None None None No 1 0 78a6.e12e.d2ef
1/3/2 Down None None None None No 1 0 78a6.e12e.d2f0
mgmt1 Down None None None None No None 0 78a6.e12e.d2e0
Please let me know if you need anything.
Thank you.
