03-31-2023 09:56 AM
Yesterday, there was power trip for 5 mins after that all access points light are not coming and it's not working. I did switch off for modem and swich for 10 mins and try it again but still light are not coming for access points.
04-24-2023 08:51 AM
Hi @viplavse
Thank you for the response and sharing the requested information.
Based on the troubleshooting done, you confirmed, and we saw that after the reset, booting up the Switch, and after trying the software recovery process multiple times, the failure persists. This Switch unit Should be RMA (Return Merchandise Authorization) in simple words replacing it.
Thank you again and we appreciate your patience.
Lennar Home Community.
04-19-2023 08:50 AM
Hi @Imran_ruckus,
Currently on switch I can see power light as green and orange light for system indicator.
04-19-2023 08:51 AM
I have total 3 access points.
04-19-2023 09:07 AM
Hi @viplavse
Thank you for the information you shared,
As you mentioned, there is an amber/orange light on the "SYST" and a green light on the "PWR" on the Switch. Meaning the Switch is stuck in the boot mode.
Basically, due to the power outage/ power spike, the switch went to a state that we call ‘boot mode’ that is not able to boot up properly.
First, we will try to reset the Switch as described below:
04-19-2023 09:09 AM
Thanks Imran, for quick response.
I have tried to do reset yesterday but all lights are keep blinking orange lights only. I wait for 10-15 mins but still it's keep blinking and not doing anything else.
Viplav
04-19-2023 09:14 AM
Hi @viplavse
As the reset is not working and amber lights are blinking, please go ahead and perform the software recovery process as described in the previous post.
Please share the screenshots if stuck at any step or error (if any) and let me know if you have any queries in this regard.
