07-31-2025 09:53 AM
Tried resetting multiple times, lights just flash on the ICX-7150
07-31-2025 11:07 AM
Hi @allans88 ,
From the response shared, I understand that the status lights on the Switch is Amber and the PWR light is Green which means that the Switch is stuck in the boot mode.
Please follow the below RUCKUS Lennar Knowledge base self-help article which will help you to fix the issue when the Switch is in boot mode.
Also, please share a clear picture showing the Switch connections.
Please follow the process as explained in the article and let me know if you have any queries in this regard.
07-31-2025 11:53 AM
I don't know where or how to enter the information to change the IP address
07-31-2025 12:37 PM
Hello @allans88 ,
May I please know if you have performed reset on Switch multiple times and if the reset still doesn’t work, could you please mention the point where you are getting stuck during Software recovery? If you could share screenshot, we could look into the matter and assist you accordingly.
Best regards, Pinky Rajendran
07-31-2025 06:24 PM
I tried the reset procedure 50 times. I tried to update the software, can't connect to the Ruckus, the UART will not load the software. The port is not active
08-01-2025 06:37 AM
Hello @allans88 ,
I understand that you are getting stuck while performing the software recovery.
I would request you to please share the cable connection between the Switch and the laptop while performing software recovery. (Please see the below picture as reference)
Also, please share the screenshot of the COM port details. COM port details should be with the silicon lab name in the device manager.
I would request you to please check if both the drivers are installed as per the software recovery article.
Once again, please make sure to download the zip drive for the file below & "extract all". Once it's extracted, run the file, the driver should be installed using the 2 links below.
Link 1: https://support.ruckuswireless.com/software/1414-brocade-ruckus-7150-usb-serial-driver-windows
Link 2: silabs.com/developers/usb-to-uart-bridge-vcp-drivers?tab=downloads
Could you please restart the laptop after installing the drivers and check the COM port details in the Device Manger from the Control Panel?
Also, please wait for few minutes and check if boot> prompt is visible.
