06-03-2024 11:54 AM
Both of my access point not powering and after power reset happened.
Tried reset in ruckus router and nothing helps .
Need direction to resolve and it was 6 year old as we got this installed when i moved to Lennar new home during 2018. Not sure if we have any warranty still exists.
06-03-2024 12:52 PM
Hi @sathishkumarrs ,
As per the case description, I understand that your RUCKUS setup is not working, and Access Points do not have power.
3.Is your Internet Connection from the Internet Service Provider (ISP) stable and working? (You could check this by connecting to your local router Wi-Fi or from an ethernet cable from the Router to a laptop/PC).
06-03-2024 03:09 PM
Thank for the response! See below my comments and pictures.
06-04-2024 06:19 AM
Hello @sathishkumarrs ,
From the pictures that was shared, I understand that the status of lights on the switch is Green and there are no lights in the access points. It is always good to check if the PoE is disabled or not.
Please follow the below RUCKUS Lennar Knowledge base self-help article which will help you to check if the PoE is disabled and to fix the issue if it is disabled.
Please follow the process and let me know if you need any help during the process.
06-04-2024 02:36 PM
Thank you so much it helps and poe was off, enabled to on now and able to access poibt getting power as well and wifi working.
Sathish
