โ07-20-2023 07:47 AM
We've been experiencing issues with the ruckus ever since the new update, but the random resetting has been happening for a few days now. However, today the APs have been resetting every ten minutes or so since this morning. There have not been any power outages as of yesterday or today. We've unplugged the unit from the power and the back of the unit itself and we've pressed the reset button on the unit. Nothing has worked. If someone could provide some guidance, it would be greatly appreciated.
โ07-20-2023 09:09 AM
Hi @JV
Hope you are doing well!!!
As per the case description, I could understand that your RUCKUS setup is not working, after Unleashed Upgrade and keeps on rebooting.
2. Is your Internet Connection from the Internet Service Provider (ISP) stable and working? (You could check this by connecting to your local router Wi-Fi or from an ethernet cable from Router to a laptop/PC).
3. May I know how many Access Points are connected to the Switch? Could you please let me know the light status on the Access Points? Any of these lights are on (Please refer to the below picture and share a picture of the same)
4. May I know what is the current version of your Unleashed system? (Please refer to the below screenshot and share the same information)
โ07-20-2023 09:56 AM
I reset the hardware to factory settings and the lights have been flashing on and off for the past hour.
1. The lights are amber and all flashing together. The only green light is the power light.
2. Yes, the internet is stable.
3. The 2 Access points of the main house are all green (power, 2.4G, and 5G).
4. The firmware version currently installed is 200.14.6.1.199
Questions: what do we do since the lights continue to flash after the factory reset? Also, since we factory reset the hardware based on a ruckus video we saw, it mentioned that we would lose our licenses, how do we recover those licenses? Finally, how do we access the CLI?
โ07-20-2023 10:13 AM
Hi @JV
You could reboot your Switch (Disconnect and connect from the power outlet)
If you still see all Amber lights on the Switch after reboot, that may be because of the software issue of the Switch and we have to perform Software recovery as described below.
We need to perform a software recovery since it can be that the image flash is corrupted in basic words the unit is not able to boot up properly and need re-install the image to boot up properly.
โ07-20-2023 12:33 PM
I need the Mac version of this. I cannot find it anywhere
