01-18-2023 01:40 PM
We have an AP that is not getting power (no lights) we have performed a factory reset and seem to have green lights on the switch. I read tutorials on it potentially being stuck on boot mode. I am not tech savvy in the slightest and this looks complicated to perform a software recovery. Is there a contact or support line where I can receive assistance via phone or get an in home visit? Our smart home devices are also not connected And the ring is causing our doorbell to chime continuously. Please help!
01-19-2023 05:31 AM
Hi @Scanlonjn
Effective November’2022, ‘Ruckus Support for Lennar Homes customers will no longer be handled by phone or email.
We will be exclusively supporting customers via this community forum support model.
Here I attach the guide to solve the issue.
Basically if the switch has one green , it means that the switch is stuck in boot mode.
If this step doesn't work, we need to perform a software recovery.
We have tried to create the guides as non-technical as possible, so that they are not difficult to follow; however, if you continue to have difficulty following the steps, I would recommend that you seek outside help or a technician.
01-25-2023 10:07 AM
We are having the exact same issue!
Our switch Box has TWO green lights which, from what I've read, is not stuck in BOOT up Mode
It will take a Rocket Scientist to figure out what is wrong. Please let me know if you have any positive results.
01-25-2023 11:06 AM
Hi @Randy
When all the system LEDs blink green after the factory reset, all the configuration data are erased and the switch is returned to its factory configuration. When all the system LEDs are solid green, the erase process is complete and the system reloads. Once reloaded and the SYST LED is steady green, the factory reset is complete.
If the Switch is not responding to the factory reset, you need to perform the software recovery process.
Please read the guide carefully before start the steps.
Ruckus ICX Recovery tutorial video
01-26-2023 06:23 PM
I’ve been trying to upgrade my Ruckus switch to regain Wi-Fi and setting up connection between switch and computer and when I go to device manager and click on (COM & LPT) there are no com choices just virtual. I tried inputting the virtual com but Putty doesn’t recognize them. I’ve been attempting this for the better part of nine hours now. Really frustrated. Any ideas?
Thank you,
Randy
