07-25-2023 02:18 AM
hi ...i already want to try recover flash using SPS08090f.bin...but after to do system-manifest the tftp server no response..ping to the server got reply is alive...and then my code flash empty how to add again ya using tftp server
my setup :
setenv ip addr 192.168.1.5
setenv serverip 192.168.1.4
setenv netmask 255.255.255.0
setenv gatewayip 192.168.1.254
setenv image_name SPS08090f.bin
update primary
07-27-2023 04:24 AM
Hi Wanji
Ack and Noted. From the version details looks like switch is running 8090d switch code. I have mentioned a link below using USB method to upgrade the switch or you can re flash the same code and check if you can see flash image populate. Please try the below procedure in the link and let me know if that helped fixing your issue.
Upgrade using console:
07-28-2023 02:24 AM
ok thnks..later i will inform u..coz today im not working
08-01-2023 09:31 AM
Hi Wanji
Ack and Noted. Please feel free to post if there are any concerns.
