01-20-2023 03:51 PM
My ruckus Poe stopped working
01-20-2023 07:40 PM
-Check if it is happening on all POE ports or just 1 poe port?
-Check the port light indication -Green or Amber if it's on 1 port and try to connect any other poe device on this interface and check if it is powering up
-“show inline power " this command will help you to find out the issue on the port
-"“show inline power detail debug” would show as “UNKNOWN” for the failed devices"
-Most of the poe related issues are fixed on this version 8095g
The best thing would be to open a support case (see my signature) so that we can check in detail if it is software or hardware issue.
Zairah Javeed
Sr Tech Support Engineer
01-30-2023 09:22 AM
Hi Team
Attaching the below doc link for reference on PoE troubleshooting. Thanks
