L3 config
dominik_musura
Hi guys, I have conf icx 48 on L3 firmware as it shows here:
telnet@ICX7150-24P Router(config)#sh run
Current configuration:
ver 08.0.90jT213
stack unit 1
  module 1 icx7150-24p-poe-port-management-module
  module 2 icx7150-2-copper-port-2g-module
  module 3 icx7150-4-sfp-plus-port-40g-module
  stack-port 1/3/1
  stack-port 1/3/3
vlan 100 name LAN by port
 untagged ethe 1/1/5 to 1/1/10
 router-interface ve 100
vlan 200 by port
 untagged ethe 1/1/13 to 1/1/15
 router-interface ve 200
enable aaa console
ip dhcp-client disable
ip dhcp-server enable
ip dhcp-server server-identifier 10.10.10.1
ip dhcp-server pool lan
 lease 1 0 0
 network 10.10.10.0 255.255.255.0
 option  3 ip 10.10.10.1
 option  6 ip 8.8.8.8
ip dhcp-server pool lan2
 lease 0 6 0
 network 10.10.20.0 255.255.255.0
 option  3 ip 10.10.20.1
 option  6 ip 8.8.8.8
 deploy
ip dns server-address 8.8.8.8 8.8.4.4
ip helper-use-responder-ip
ip route 0.0.0.0/0 192.168.1.1
username super password .....
web-management https
sz registrar
sz active-list 10.164.0.3 34.90.89.117
interface ethernet 1/1/1
 ip address 192.168.1.231 255.255.255.0
interface ethernet 1/3/1
 speed-duplex 1000-full
interface ethernet 1/3/2
interface ethernet 1/3/3
interface ethernet 1/3/4
interface ve 100
 ip address 10.10.10.1 255.255.255.0
interface ve 200
 ip address 10.10.20.1 255.255.255.0
end
I cannot ping anything outside the gateway network from the vlan 100.
Any ideas?
8 REPLIES 8
corey_costello
What are you trying to ping?
Are there routes on that device that terminates @ L3 whatever youre trying to ping?
Hello dominik_musura,
It would be helpful to see outputs like:
ping x.x.x.x
show arp x.x.x.x
show ip route x.x.x.x
have you tried to ping the other way back?
we can check if the ping is getting to the ICX with 'debug ip icmp packets' + 'debug destination <telnet/ssh number>'
Let us know your comments!
With regards,
Orlando Elias
Technical Support
@corey_costello I am trying to ping 8.8.8.8 and other devices on 192.168.1.0/24 network from vlan 100.
I will send tonight icmp export
I cannot ping other way either.
