07-10-2023 03:30 PM
I've been trying to add an interface to a LAG that I recently created and when I go to add the interface to the LAG I get
"Error - Port x/x/x has Flexauth enabled on it
LAG ports adding validation failed"
I found the documentation on how to configure Flexauth and tried doing the opposite with no luck. Is there something I'm missing, because I am at a loss.
07-11-2023 03:41 AM
Hi Atoctoc
Thank you for reaching us
If its a new setup and the interface you are trying to add has authentication enabled then try to remove all the authentication details configured in the interface which you are trying to add to LAG and see if you can add the interface to LAG.
Based on the problem description I suppose there would be a need for you to share more details from your network setup. Please use the below link and see if you can log a case with us.
07-11-2023 03:41 AM
Hi Atoctoc
07-11-2023 12:10 PM
Chandini,
I thought I had already removed MAC authentication from the interface, but that was not the case. Once I removed it I no longer had the Flexauth issue.
I appreciate the help!
