12-17-2025 08:17 AM
I am not sure what has happened over night other than it rained, but I have a Back-UPS connected to the switch to prevent power outage issues as I had an issue on the switch within the first 6 months due to a power outage. It is a Lennar home that has the ICX-7150-C12P switch with three R510 APs connected to an AT&T Fiber Modem (BGW320-500).
Internet is connected via C1 port. I have pulled the power on the switch and powered back on but the router is not seeing the switch when I connect to any ports including the C1 and C2 ports. When i connect to the Out-of-band management port (RJ-45) with 2 LEDs, I get connection to the router. What is needed to get my switch and AP connected. I really don't want to reset the switch as it will take a lot of configuration to get it all set back up.
My suspicion is the switch is faulty.
12-17-2025 09:13 AM
Hello @Jota31 ,
As per the case description, I understand that your RUCKUS setup is not working after the power outage
On your switch while it's plugged into the outlet, do you see any lights on? (Amber or green) Please let us know which lights are on. (Please refer to the below picture and share a picture of the same, showing the light status and the FULL Switch panel cable connections to the Switch ports)
Also, please share the light status of your Access points as well as mentioned in the below picture:
12-17-2025 10:37 AM
Hello @Jota31 ,
From the response you shared, I understand that the status lights on the Switch is Amber and the PWR light is Green, which means that the Switch is stuck in a boot mode
Please follow the below RUCKUS Lennar Knowledge base self-help article which will help you to fix the issue when the Switch is in boot mode.
Please follow the process as explained in the article and let me know if you have any queries in this regard.
12-18-2025 10:13 AM
Hi @Jota31 ,
This issue is because your switch is running on the Routing code (SPR). The Switch should run on the Switching code (SPS) to avoid these issues for Lennar home users. Due to a power outage/power spike, the Switch boots up on the other partition which may be running on a ‘Routing Code’ results in causing this issue.
As I can see from the output you shared, your Switch is booted up on the secondary partition which is running on Routing code (SPR) as highlighted in the below screenshot.
Please follow the below RUCKUS Lennar Knowledge base self-help article which will help you to fix the issue when the Switch is running in the Routing code.
12-18-2025 10:39 AM
I realized that I did it incorrectly. I copied the wrong file over during the software recovery process.I used the SPR08090k.bin instead of SPS08090k.bin. I noticed in the link i would need to have SPS in the primary before I can flash.
When I use the commands from the link.
Does that mean I have to start from scratch and upload the correct SPS?
12-18-2025 11:45 AM
Hello @Jota31 ,
I would request you to please replace the SPR file with the SPS file as the SPR file would make the Switch runs on the Routing code.
The Routing code will makes the network slow, and even might lead the Switch to drop off automatically.
12-18-2025 12:20 PM
I am following the instructions from
and I am unable to get the prompt
ICX7150-Boot>
The prompt I am getting is ICX7150-C12 Router>.
How do I get back to that prompt when my router is already up and running and no longer stuck.
12-18-2025 12:45 PM
Hello @Jota31
As you are getting the Router prompt, please follow the below RUCKUS Lennar Knowledge base self-help article which will help you to fix the issue when the Switch is running in the Routing code.
