06-07-2023 07:41 PM
Where can I find some documentation on how to downgrade the switch firmware from 09.0.10c to the recommended 08.0.95j release?
I have issues with 802.1x implementation so I'd like to downgrade my firmware in the Dev environment.
06-07-2023 09:07 PM
Hello Rahul,
The downgrade process is similar to the upgrade process.
Please find the steps below for downgrading the switch:
How to download the Software? Go to: https://support.ruckuswireless.com//
1. Click on "download"
2. Choose the product (Ruckus ICX7xx Campus Switches)
3. Download the required version
Steps for downgrading via TFTP
1. Charge the software on a TFTP server, the TFTP server should have ping connectivity with the switch.
2. Get console access and test the ping connectivity with the command brocade# ping x.x.x.x. Note: if you have a stack get console access from the active controller.
3. Issue the Show flash command to confirm e version.
4. Upgrade the image software version on primary/secondary partition
Switch# copy tftp flash x.x.x.x <filename> primary/secondary ("show flash" to confirm)
NOTE: On a stack environment implement the upgrade from the active controller and it will copied to the member automatically.
6. Boot from primary/secondary partition
Switch# boot system flash primary/secondary.
Video Guide https://www.youtube.com/watch?v=DHIEajPhHWQ&t=15s - This is for upgrade
7. Upgrading to 8095h UFI desired version.
8. Once the switch is up, please verify if it has upgraded successfully via "show version" command
Note : Please take a config backup, prior to the downgrade(few of the features may not support in the downgraded version).
Also refer below links regarding limitations and consideration:
Please feel free to revert if any further query.
Nidhi
