ICX 7150: Not letting me create a Router-Interface
HELP!!!
I've been trying to create a vlan with its own dhcp server, however for some reason my switch is not letting me create a router-interface. I do have the dhcp pool ready for it, though.
below is code:
ICX7150-C12 Switch(config)#vlan 30
ICX7150-C12 Switch(config-vlan-30)#tagged e 1/1/3
Added tagged port(s) ethe 1/1/3 to port-vlan 30.
ICX7150-C12 Switch(config-vlan-30)#tagged e 1/1/4
Added tagged port(s) ethe 1/1/4 to port-vlan 30.
ICX7150-C12 Switch(config-vlan-30)#untagged e 1/1/5
Added untagged port(s) ethe 1/1/5 to port-vlan 30.
ICX7150-C12 Switch(config-vlan-30)#router-interface ve 30
Invalid input -> router-interface ve 30
Type ? for a list
ICX7150-C12 Switch(config-vlan-30)#exit
ICX7150-C12 Switch(config)#show run
Current configuration:
ver 08.0.70cT211
stack unit 1
  module 1 icx7150-c12-poe-port-management-module
  module 2 icx7150-2-copper-port-2g-module
  module 3 icx7150-2-sfp-plus-port-20g-module
vlan 30 by port
 tagged ethe 1/1/3 to 1/1/4
 untagged ethe 1/1/5
dhcp-gateway-list 10 192.168.30.1
ip address 192.168.1.90 255.255.255.0
no ip dhcp-client enable
ip dhcp-server enable
ip dhcp-server pool testvlan30
 excluded-address 192.168.30.1
 lease 1 0 0
 network 192.168.30.0 255.255.255.0
 option  3 ip 192.168.30.1
 deploy
username telepro password .....
username user password .....
username ruckus password .....
username admin password .....
interface ethernet 1/3/1
 speed-duplex 1000-full
interface ethernet 1/3/2
end
21 REPLIES 21
jon_maiman_iyni
Please capture the output from the following commands and post it to the thread:
Skip
Show run
Show Version
Show Ip Int
Show Ip Route
page
Best guess without more information is you don't have a "WAN" IP address for the port connected to the Internet.   Since the ICX7150 is running router code, you need to be able to route up to the Internet.   Second guess is your Upstream Internet Router doesn't have routes back to your ICX7150 for the locally hosted subnets you created.   The output from the above commands should help isolate the problem.
--Jon
please see below:
ICX7150-C12 Router(config)#skip
Invalid input -> skip
Type ? for a list
ICX7150-C12 Router(config)#show run
ver 08.0.70cT213
stack unit 1
global-stp
vlan 2 name IP-Subnet_10.1.2.0/24 by port
vlan 30 by port
 untagged ethe 1/1/6 to 1/1/12
boot sys fl sec
 lease 1 0 0
 deploy
ip route 192.168.30.0/24 192.168.1.254
interface ve 30
 ip address 192.168.30.1 255.255.255.0
end
ICX7150-C12 Router(config)#Show Version
  Copyright (c) 2017 Ruckus Wireless, Inc. All rights reserved.
    UNIT 1: compiled on Aug 30 2018 at 04:48:29 labeled as SPR08070c
      (29437672 bytes) from Secondary SPR08070c.bin
        SW: Version 08.0.70cT213
      Compressed Boot-Monitor Image size = 786944, Version:10.1.13T225 (mnz10113)
       Compiled on Tue Jul 24 10:23:08 2018
  HW: Stackable ICX7150-C12-POE
      Serial  #:FEK3811Q1WN
      Current License: 2X1G
      P-ASIC  0: type B160, rev 11  Chip BCM56160_B0
 8192 KB boot flash memory
 2048 MB code flash memory
 1024 MB DRAM
STACKID 1  system uptime is 38 minute(s) 25 second(s)
The system started at 00:01:54 GMT+00 Sat Jan 01 2000
ICX7150-C12 Router(config)#Show Ip Int
Interface           IP-Address      OK?  Method    Status             Protocol   VRF
Ve 30               192.168.30.1    YES  NVRAM     up                 up         default-vrf
ICX7150-C12 Router(config)#Show Ip Route
Total number of IP routes: 1
Type Codes - B:BGP D:Connected O:OSPF R:RIP S:Static; Cost - Dist/Metric
BGP  Codes - i:iBGP e:eBGP
OSPF Codes - i:Inter Area 1:External Type 1 2:External Type 2
        Destination        Gateway         Port          Cost          Type Uptime
1       192.168.30.0/24    DIRECT          ve 30         0/0           D    39m7s
ICX7150-C12 Router(config)#page
Invalid input -> page
Type ? for a list
please see below:
Type ? for a list
ver 08.0.70cT213
stack unit 1
global-stp
vlan 30 by port
boot sys fl sec
 lease 1 0 0
 deploy
interface ve 30
end
 1024 MB DRAM
Type ? for a list
jon_maiman_iyni
As I suspected, you don't have a "WAN" IP Address to your upstream Internet Router.    From when you connected your laptop to the Internet directly, your IP Subnet for the Internet is 192.168.1.0/24 and your gateway (next hop) is 192.168.1.254.    You can create a VE in VLAN 1 (the default VLAN) and have it get an address via DHCP.   The config. would be approx.:
vlan 1
router-interface ve 1
interface ve 1
ip dhcp-client
You will still need the default route to the internet:
ip route 0.0.0.0/0 192.168.1.254
However, this only fixes the problem in one direction (sending traffic upstream to the Internet).   You will need a route on your Internet Gateway pointing to your ICX switch for the 192.168.30.0/24 network for downstream traffic.
This begs the question, if you only plan on having one IP Subnet 192.168.30.0 on your ICX Switch, why are you running router code?   Wouldn't it be simpler to just use your switch as layer 2 only and configure your Internet Gateway to handout addresses in the 192.168.30.0 subnet for clients?   Since the Internet Traffic will be NAT'ed anyway, you really could just leave the DHCP clients be assigned in the 192.168.1.0 subnet your Internet Gateway is already configured for.
--Jon
