05-13-2024 03:23 PM
Current firmware on Switch: 08.0.95fT211
I am trying to upgrade for the firmware and was looking at older posts. I downloaded the latest patch which is 08.0.95n but it doesn't have "boot" folder. Has upgrading firmware changed? Can someone post the instructions?
05-14-2024 06:26 AM
Hi Steven_wong_hli
Thank you for reaching us
From the details I suppose you wanted to understand why boot folder are not seen on version 8095n.
8095 versions are UFI image so when you upgrade the using .bin file available in image folder would include boot code , image and PoE firmware all in the same software file.
I suppose this could be the reason why the boot folder is not seen in the software files.
I hope this helps
