05-13-2024 03:23 PM
Current firmware on Switch: 08.0.95fT211
I am trying to upgrade for the firmware and was looking at older posts. I downloaded the latest patch which is 08.0.95n but it doesn't have "boot" folder. Has upgrading firmware changed? Can someone post the instructions?
05-14-2024 06:26 AM
Hi Steven_wong_hli
Thank you for reaching us
From the details I suppose you wanted to understand why boot folder are not seen on version 8095n.
8095 versions are UFI image so when you upgrade the using .bin file available in image folder would include boot code , image and PoE firmware all in the same software file.
I suppose this could be the reason why the boot folder is not seen in the software files.
I hope this helps
05-14-2024 06:26 AM
Hi Steven_wong_hli
I hope this helps
05-27-2024 09:12 PM - edited 05-27-2024 11:06 PM
Figured it out thank you!
05-27-2024 10:30 PM - edited 05-27-2024 10:41 PM
Deleted
05-28-2024 07:38 AM
Hi @steven_wong_hli
Could you please let me know if this is a Lennar Home RUCKUS setup?
Please confirm.
Thank you again.
