Help: Log Into ICX-7150C12
Gordo_GT
I attempted to set a password on the switch by using the CLI connection on a Mac, but for some reason, I can't make the password update stick nor am I able to login when accessing the switch IP address on a web page. Any suggestions? Current firmware is 08.0.70bT211
Here is where I am at within Terminal:
"ICX7150-C12 Switch>
  enable            Enter Privileged mode
  nslookup          Nslookup Utility
  ping              Ping IP node
  show              Display system information
  stop-traceroute   Stop current TraceRoute
  traceroute        TraceRoute to IP Node
ICX7150-C12 Switch>enable
ICX7150-C12 Switch#"
2 REPLIES 2
Gordo_GT
I solved the issue by following steps 1,3, and 4 of the linked site: https://luiscachog.io/configure-ruckus-switch/. Next topic, what guide may I follow to update the firmware on the switch?
happytohelp
RUCKUS Team Member
Hi Gordo_GT,
Since you're currently on 8070b, you will have to perform a step upgrade. You can follow below document:
https://docs.commscope.com/bundle/fastiron-08095-upgradeguide/page/GUID-5DD7EE86-6988-4CA7-81D2-22EA...
Type a product name
