Default VLAN Dot1x Radius
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
11-13-2022 11:49 PM
we run a bunch of 7450 and 7250 in Switching mode and Setup a NPS ( Windows Radius ) with eap-tls cert auth like this:
authentication
auth-mode multiple-untagged
auth-default-vlan 160
restricted-vlan 1002
re-authentication
auth-fail-action restricted-vlan
dot1x enable
dot1x enable ethe 1/1/39
dot1x port-control auto ethe 1/1/39
radius-server host rad.ip.add.ress auth-port 1812 acct-port 1813 default key 2 mysecretkey dot1x
If I try to connect clients to our default VLAN ( Radius returns U:Default-VLAN ) I get the following error message: Parse error as VLAN-ID XXX is used as sys-def-vlan
Can I not use my Default VLAN for dot1x radius auth ? If so is there a way on ICX to move all ports from one VLAN to another ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-14-2022 03:31 PM
Hi @S4mrai
It seems that VLAN 160 is your default VLAN, which by the way cannot be the same VLAN for authentication with 802.1x,that's the conflict you are getting.
Yarenis Hernández
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-15-2022 06:56 AM
my Default VLAN is 1 in this scenario not 160 sorry I left that out
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-15-2022 08:04 AM
Hi @S4mrai
I will advise opening a case with the TAC, so we can assist you, check the all configuration a possible debugging.
Yarenis Hernández
