07-07-2021 02:24 AM
Dear All,
Hope all find in good health.
One of my ICX 7250-48P switch is equipped with VOIP phone , POE is working great and stability .
Last 2 week ago Switch POE function is suddenly stop but all config and switch function is working as usual. i try to reload switch and inline power disable /enable but didn't work .
My question is ,
1- It Hardware error or software error . can we fix it ?
2- Why is this happening and how to check it .
3- Can i clear the config and use it on other functions that no need require POE (Data Switch)
4- How to clear the config as factory default .
Thanks ,
YZY
07-08-2021 11:39 AM
HI ye_zey,
The power supply is good:
Power supply 1 (AC - PoE) present, status ok
The POE Hardware looks good as well:
Device HW version : 0:V2R2 1:V2R2 2:V2R2 3:V2R2 4:V2R2 5:V2R2
The POE firmware for 8061 code is good as well:
Firmware
Version
01.8.8 Build 001
I think we will need further debug via a TAC case.
Please open a TAC case at link below:
Hope this helps.
Hashim
07-08-2021 07:45 AM
Hi @hashim_bharoocha ,
Please see below running config output . currently those switch have no device equip .
#Show Inline Power Detail
Power Supply Data On unit 1:
Power Supply Data:
Power Supply #1:
Max Curr: 13.7 Amps
Voltage: 54.0 Volts
Capacity: 740 Watts
PoePower: 740 Watts
power supply 2 is not present
power supply 3 is not present
POE Details Info. On Unit 1 :
General PoE Data:
Firmware
Version
01.8.8 Build 001
Hardware
Version
V2R2
Cumulative Port State Data:
#Ports #Ports #Ports #Ports #Ports #Ports #Ports
Admin-On Admin-Off Oper-On Oper-Off Off-Denied Off-No-PD Off-Fault
23 25 0 48 0 23 0
Cumulative Port Power Data:
#Ports #Ports #Ports Power Power
Pri: 1 Pri: 2 Pri: 3 Consumption Allocation
0 0 23 0.000 W 0.000 W
#Show inline power detail debug-info
sh inline power detail debug-info
Power Supply Data:
Power Supply #1:
Max Curr: 13.7 Amps
Voltage: 54.0 Volts
Capacity: 740 Watts
PoePower: 740 Watts
General PoE Data:
Firmware
Version
01.8.8 Build 001
Hardware
Version
V2R2
Note: Number of PoE Devices:6. This number of LSBs should be zero
in devFaultMap, devTempOff,devTempAlarm
First System Status:
cpuStatus1 (fwDnldReq:0, errController:0), cpuStatus2(errMemory:0),
factoryDefault:0, genInternalErr:0, privateLabel:0, userByte:f3,
devFaultMap:c0, devTempOff: 0, devTempAlarm: 0, intReg:f0cc
Latest System Status:
factoryDefault:0, genInternalErr:0, privateLabel:0, userByte:0,
devFaultMap:0, devTempOff: 0, devTempAlarm: 0, intReg:f0cc
Device Temperature(deg-C) : 0:40 1:40 2:42 3:40 4:38 5:37
Device VOP Test Status : 0:0 1:0 2:0 3:0 4:0 5:0
23 25 0 48 0 23 0
#Show Chassis
sh chassis
The stack unit 1 chassis info:
Power supply 2 not present
Power supply 3 not present
Fan 1 ok, speed (auto): [[1]]<->2
Fan 2 ok, speed (auto): [[1]]<->2
Fan 3 ok, speed (auto): [[1]]<->2
Fan controlled temperature:
Rule 1/2 (MGMT THERMAL PLANE): 59.0 deg-C
Rule 2/2 (PoE THERMAL PLANE): 18.5 deg-C
Fan speed switching temperature thresholds:
Speed 1: NM<-----> 95 deg-C
Speed 2: 85<----->105 deg-C (shutdown)
Speed 1: NM<-----> 41 deg-C
Speed 2: 34<----->105 deg-C (shutdown)
Fan 1 Air Flow Direction: Front to Back
Fan 2 Air Flow Direction: Front to Back
Fan 3 Air Flow Direction: Front to Back
Slot 1 Current Temperature: 59.5 deg-C (Sensor 1), 18.5 deg-C (Sensor 2)
Slot 2 Current Temperature: NA
Warning level.......: 100.0 deg-C
Shutdown level......: 105.0 deg-C
Boot Prom MAC : 78a6.e108.5278
Management MAC: 78a6.e108.5278
#Show Version
Copyright (c) 1996-2017 Brocade Communications Systems, Inc. All rights reserved.
UNIT 1: compiled on Aug 14 2017 at 06:54:44 labeled as SPS08061a
(24723488 bytes) from Primary
SW: Version 08.0.61aT211
Compressed Boot-Monitor Image size = 786944, Version:10.1.10T215 (spz10110)
Compiled on Sun Jun 25 15:56:29 2017
HW: Stackable ICX7250-48-HPOE
UNIT 1: SL 1: ICX7250-48P POE 48-port Management Module
Serial #:DUK3829N05L
License: BASE_SOFT_PACKAGE (LID: fwmINHOpFKn)
P-ASIC 0: type B344, rev 01 Chip BCM56344_A0
UNIT 1: SL 2: ICX7250-SFP-Plus 8-port 80G Module
8192 KB boot flash memory
2048 MB code flash memory
2048 MB DRAM
STACKID 1 system uptime is 17 hour(s) 48 minute(s) 6 second(s)
The system started at 03:27:13 GMT+06:30 Thu Jul 08 2021
The system : started=warm start reloaded=by "reload"
07-08-2021 11:39 AM
HI ye_zey,
Firmware
Version
01.8.8 Build 001
Hope this helps.
Hashim
07-09-2021 01:39 AM
Thanks you for your comment . i will open the case .
07-09-2021 11:09 PM
Hi Ye_zey,
You are most welcome!!!
Hashim
