04-30-2023 04:54 AM
Hi
Our company had standardized on the P300 for P2P communications between buildings.
But P300 is eol.
We are very happy with the P300.we want to buy backup P300. But there is no P300 product anymore.
What is a replacement device for P300 for P2P communication ?
in the P300 , there is never a time out in the communication between two buildings.
it should definitely be like P300 or higher in terms of features and quality. !!!
Thank you very much
05-01-2023 03:09 AM
@seckin_onder If you are looking for device with similar performance/feature as p300 unfortunately it won't be available. P300 was an p2p/p2m bridge device whereas the alternate we suggest are an WiFi APs which when used with smartmesh technology can act as bridge unit.
Best Regards
Vineet
05-01-2023 02:02 AM
i saw this post.But here it says it is not clear,not definitely.
05-01-2023 02:06 AM
P300 were P2P devices which we no longer make and hence the only alternative would be the outdoor APs with smart mesh (t350 or even t750)
Best Regards
Vineet
05-01-2023 03:02 AM
Thank you.
P300 Target udp througput 1200 Mbps , but t350 doestnt have this.
P300 has no user capacity limit ,but t350 has 512 user capacity.
Could the t350 be lower in quailty than p300 ?
05-01-2023 03:09 AM
Best Regards
Vineet
05-01-2023 03:19 AM
Do you have any information why ruckuss does not produce p2p/p2m device or
do you konw if it will produce it in the near future ?
if you dont know , how can i find out they will produce devices in the near future ?
