P300 and Replacement
seckin_onder
Hi
Our company had standardized on the P300 for P2P communications between buildings.
But P300 is eol.
We are very happy with the P300.we want to buy backup P300. But  there is no P300 product anymore.
What is a replacement device for P300 for P2P communication ?
in the P300 , there is never a time out in the communication between two buildings.
it should definitely be like P300 or higher in terms of features and quality. !!!
Thank you very much
1 ACCEPTED SOLUTION
@seckin_onder If you are looking for device with similar performance/feature as p300 unfortunately it won't be available. P300 was an p2p/p2m bridge device whereas the alternate we suggest are an WiFi APs which when used with smartmesh technology can act as bridge unit.
Best Regards
Vineet
14 REPLIES 14
sanjay_kumar
RUCKUS Team Member
Hi @seckin_onder
Please find the link below for the list of available products based on the requirement.
https://www.ruckusnetworks.com/products/wireless-access-points/?r=1
Thank you.
Which one would you recommend with the same or above quality as the p300?
Which of these products is close to p300? t750 or t350
Please help me
@seckin_onder
Please go through the below discussion which would help you :
https://community.ruckuswireless.com/t5/Access-Points-Indoor-and-Outdoor/P300-EOL-replacement/m-p/44...
Best Regards
Vineet
