04-30-2023 04:54 AM
Hi
Our company had standardized on the P300 for P2P communications between buildings.
But P300 is eol.
We are very happy with the P300.we want to buy backup P300. But there is no P300 product anymore.
What is a replacement device for P300 for P2P communication ?
in the P300 , there is never a time out in the communication between two buildings.
it should definitely be like P300 or higher in terms of features and quality. !!!
Thank you very much
05-01-2023 03:09 AM
@seckin_onder If you are looking for device with similar performance/feature as p300 unfortunately it won't be available. P300 was an p2p/p2m bridge device whereas the alternate we suggest are an WiFi APs which when used with smartmesh technology can act as bridge unit.
Best Regards
Vineet
04-30-2023 11:35 PM
Hi @seckin_onder
Please find the link below for the list of available products based on the requirement.
https://www.ruckusnetworks.com/products/wireless-access-points/?r=1
04-30-2023 11:48 PM - edited 05-01-2023 12:46 AM
Thank you.
Which one would you recommend with the same or above quality as the p300?
Which of these products is close to p300? t750 or t350
05-01-2023 12:58 AM
Please help me
05-01-2023 01:56 AM
Please go through the below discussion which would help you :
Best Regards
Vineet
