vSZ webUI unavailable (rel 3.4.2)
rick_macchio
I tried installing a single controller running 3.4.2 via .ova and the setup went smoothly until I got to the point where I tried connecting on port 8443. The controller is reachable via SSH and otherwise appears to be fine. I've noticed that I can't seem to turn on the web service but there are not errors explaining why.
Welcome to the Ruckus Virtual SmartZone - Essentials Command Line Interface
Version: 3.4.2.0.152
new-host-3> en
Password: *********
new-host-3# show service
No. Application Name Health Status Log Level # of Logs
1 API Offline 0
2 CNR Online 1
3 CaptivePortal Online 6
4 Cassandra Offline 4
5 Configurer Online 6
6 Core Offline 6
7 EAut Online 2
8 ElasticSearch Online 4
9 LogMgr Online 2
10 MdProxy Online 1
11 MemProxy Online 1
12 Memcached Online 1
13 Mosquitto Online 1
14 MsgDist Online 1
15 NC Online 1
16 NginX Online 3
17 Observer Online 1
18 OnlineSignup Offline 1
19 RadiusProxy Offline 0
20 SCIAgent Online 2
21 SNMP Online 1
22 SessMgr Online 1
23 SubscriberManagement Offline 2
24 SubscriberPortal Offline 2
25 Web Offline 4
new-host-3# service start
Please note that this command will cause current SSH connection closed for SSH restart. Do you want to start all services (or input 'no' to cancel)? [yes/no] yes
Starting all services...
Process had been started before and running...
System already startup, skip startup process...
Successful operation
1 API Offline 0
2 CNR Online 1
6 Core Offline 6
7 EAut Online 2
9 LogMgr Online 2
10 MdProxy Online 1
14 MsgDist Online 1
15 NC Online 1
16 NginX Online 3
21 SNMP Online 1
22 SessMgr Online 1
25 Web Offline 4
new-host-3# show mem
MemTotal: 15432828 kB
MemFree: 192352 kB
Buffers: 9196 kB
Cached: 259852 kB
SwapCached: 0 kB
I haven't plugged in any APs yet. Just wanted to get this part running first. Any help would be appreciated.
16 REPLIES 16
Anusha_Vemula
Community Manager
Community Manager
Hi Tien,
I believe you are talking about the AP flagged status. Please share a screenshot to assist you better.
- Anusha
tien_phan_anotw
Contributor
Image_ images_messages_5f91c45d135b77e247a48359_3c7ff32bb40698e25fafeb3f8b1781dc_RackMultipart201909048451316z2-caeb6550-66d2-4f9e-aaed-d9bef2d7d44a-1191049988.png1567582070
Sure, that's `Flagged` at Controller.
tien_phan_anotw
Contributor
Hi Anusha,
How long does vSZ-E take to start all services? (In case vSZ-E reset/ reboot).
Thank you.
Anusha_Vemula
Community Manager
Community Manager
Hi Tien,
Please check the threshold values configured for the cluster status and increase the resources if required.
Image_ images_messages_5f91c45d135b77e247a48aa4_382071e2dfe705b116bde79124b1f4b2_RackMultipart2019090425077not8-083174e8-13b0-4b97-bc33-3b961452c89d-1164680004.png1567599207
If you reboot the controller, it takes 30 to 45 minutes to restart all the service depending up on the configuration done on the controller.
- Anusha
Anusha, I a have a controller SZ-100 in version 3.6.2.0.0.222( the recommend firmware) and after a normal reboot all services is now offline and not going up.
I am facing this issue in every version that I enable in the setup the dual ipv4/ipv6 option, at least in this version We were able to have it working after setup but after tried to upgrade to any firmware 5+ and always getting ''fail to upload reason: general error" We decide to try a reboot.  But unfortunately the the services problem is happening again. What is the catch ? This is already a new controller, because original one we open a RMA to see if it was a problem with the HD...
