10-17-2021 07:47 PM
I have both vSZ & Data Plane instances installed. I have an issue where when enabled in tunnel mode, it stops broadcasting the SSID for some strange reason. However when I do disable the tunneling method in vSZ - the AP starts to broadcast the SSID again. I have these instances installed on a bare metal @ a colocation center.
Any ideas about what it could be? I read a post on here about doing the:
get tunnelmgr
However I'm not entirely sure what it is that I'm looking for in this output. It says on that post that the AP may not be able to see the controller when doing data plane functionality?
I'm currently running this environment in Essentials mode.
10-18-2021 04:06 AM
SSID isn't broadcasted, because connection to vDP is not established. I am quit sure that it is some firewall or routing issue.
10-18-2021 11:50 AM
I have the port forwards for this. in the above reply. Any ideas what else it could be?
vSZ: 192.168.8.7
vDP (ctrl): 192.168.8.10
vDP (mgmt): 192.168.9
is this setup not advisable? I see where a lot of the data is on an entirely separate network.
10-18-2021 10:50 PM
For your SSID to work, you need 2 separate things to happen:
AP must establish SSH tunnel to vSZ (for management)
AP must establish tunnel to vDP (for SSID traffic)
So what is the status of AP? Is it shown in vSZ as online? If yes, than SSH tunnel to vSz is established. I suppose, it is
But tunnel for SSID data is not established, and seems that it shows wrong IP (tunnel can't be established to internal IP, it must show routed IP). Do you have configured external IP in vDP configuration? It is neccessary same way, as external IP for vSZ.
10-19-2021 01:25 AM
Try these pings to discard a networking issue:
10-19-2021 03:48 PM
On the vDP, I'm able to ping the GW.
I'm on the AP CLI, however I'm connected to via the DHCP sever (on premises where the AP is) and I'm unable to ping the internal GW (remote GW where vSZ/vDP is), I can ping the NAT IP.
