vSZ - command "set scg ip" not allowed in AP script
mrwolf
Hi all,
we need to change IP address of our vSZ-H, which is hosted on our own public cloud infrastructure.
Though we are pretty confident that we did it well in the past, declaring FQDN instead of IP address in "set scg ip" command, we want to make sure that all of our APs are correctly configured before going live with new IP address.
APs are distributed over many customers, thus DHCP 43 is not an option.
We would like to push an AP script command, as suggested in the following KB article: https://support.ruckuswireless.com/articles/000004979
Also, as per this article, "any AP CLI command will be accepted" into the AP script.
However, when we upload the script, we get the following error: "command[set scg ip] is not allowed in AP CLI Script file."
Script is very simple, as following:
#define AP FW version
fw_version=5.1.0.0.595 #define Model class model=all # Command set scg ip FQDN
Any clue on how to upgrade scg ip remotely (with no easy SSH access)?
11 REPLIES 11
mrwolf
Thank you guys for your hints. Since we're talking about only 10 to 20 APs with scg configured as IP address instead of FQDN, I think we'll proceed manually with remote-ap-cli (if it works).
To avoid having the same problem in the future, we would like to put FQDN also in ICX switches configurarion. However, it seems to accept IP addresses only. Do you know if this is going to change on future fw releases?
syamantakomer
Community Admin
Community Admin
Hi All,
SZ has an option called switch over cluster.
Use it to move your AP from one Cluster to another, it is safe, simple and it always works.
Refer the link below.
https://docs.commscope.com/bundle/sz-512-sz100-vsze-administrator-guide/page/GUID-083279C0-ED57-4024...
Syamantak Omer
RUCKUS Networks, CommScope!
Follow me on LinkedIn
