vSZ-D count number of tunnels for remote sites
Liinad
I can't seem to find the answer to this. From the documents that I read a vSZ-D can support 10000 tunnels but it wasn't clear to me how to count those tunnels.
Theoretical scenario: I am using 1000 off-site APs that are broadcasting 3 SSIDs each. All trafic is being tunneled to my vSZ-D. How many tunnels would need to be created?
My understanding is that I require 1 tunnel per SSID per AP so 3x1000=3000. Is this correct and if not can someone explain to me how to count them correctly?
1 ACCEPTED SOLUTION
albert_pierson
RUCKUS Team Member
Hi liinad,
Yes - if you have 1000 AP's with one or more Tunneled WLAN/SSID then the DP/vDP will be terminating 1000 tunnels.  It is one Tunnel per AP and Tunnel is only created when one or more WLAN/SSID are configured for rGRE (Ruckus GRE) tunnels.
I hope this answers your question.
Thanks for choosing RUCKUS products.
5 REPLIES 5
Hello Albert,
Yes this answered my question, thank you very much.
