smart zone 100 redundancy connection
Hi, please help me in the description of connection phisycal between two sz100 in mode clustering. As it should be the connection to the switches that are in
Redundancy vrrp.
thanks
12 REPLIES 12
Esteemed Contributor II
Question not clear.  You can connect one port from each SZ-100 into two different switches,
and STP will block one path to each.  SZ-100 does not run VRRP.
Hello
How to physically redundant 2 to controller SmartZone 100?
Hi everyone,
I have a SmartZone100 and want to add another for redundant, is any way to connect two ZD together? Is it supported?
If yes whats the configuration?
Vineet_nejwala
Hello Rahimi,
Yes, both v/SZ and ZD can be setup to use as redundant controller, with SZ you have two option 1)Active-active or 2) Active-Standby (Geo-redundancy) whereas with ZD only Active/Standby is supported. Kindly let us if you need redundancy setup with ZD or v/SZ.
Best Regards
Vineet
