12-30-2020 10:55 PM
hi
i have questions for maximum DHCP(DP) pool in vSZ-H with SZ144-D
i can't find in manual
01-02-2021 06:18 AM
Even 1000 hosts in same VLAN is a usually a bad idea. Exception is when full client isolation is enabled.
Anyway, exactly to address big number of clients on the same SSID SmartZone supports VLAN pooling -- so multiple VLANs can be attached to the same SSID. This feature is needed in big public venues mostly (stadiums, etc.), and you just use as much VLANs as you need -- 2/4/8/16 etc.
Hope it helps.
01-04-2021 03:06 AM
300 000 clients?! It's something ... For how many APs? Can't imagine real project, which supports that much clients. I have really seen something only on scale of ~10 000 simultaneous users on the same system, and thought this is quit a lot, but this is different scale and really a lot more!
Only case I can imagine for that is some service provider with many thousands of APs in different locations, in this case you probably can leave with such big subnets, using traffic isolation.
I suggest you discuss with Ruckus development what is the best way to handle that, as it is definitely not a typical situation, and they are best positioned to recommend the best solution for such project.
Hope it helps,
01-04-2021 03:21 AM
It is unpredictable how many concurrent users there will be, but expect many devices to be connected. ( could be more or less )
So we are investigating the limitations of each element to design the configuration.
