What does the alarm "Cluster [VSZ01-3-6-C] is in maintenance state." indicate?
cesar_murilo
Virtual SmartZone version: 3.6.2.0.222
What does the alarm below indicate? In which log can I see what really happened, since I downloaded Diagnostics -> Applications Logs -> Download All Logs, looked at several and found nothing related on the date it occurred?
020/06/29 17:32:31
804
Cluster in maintenance state
Critical
Cleared
3 REPLIES 3
syamantakomer
Community Admin
Community Admin
Hi Cesar,
Usually system will go to maintenance mode due below two reasons.
1- While creating a cluster backup
2- Creating a configuration backup
Please note that it is not limited to just above two reasons, as system may also enter into maintenance mode while a firmware upgrade, service down/restart etc.
Syamantak Omer
Syamantak Omer
RUCKUS Networks, CommScope!
Follow me on LinkedIn
And among these possibilities, can I know the specific reason? As I said, I looked at several logs and found nothing. If I can find the right item you mentioned, which log would I have to see?
saurabh1991
RUCKUS Team Member
Hi Cesar,
Yes, we can look for the actual reason from the snapshot logs > applogfile > configurer folder (search with keyword "state").
i.e.
2023-06-20 08:25:25,842 Configurer[internalScheduler-11] INFO c.r.w.c.o.ClusterBackupOperationService - <OPT> [Backup] requests all blade to take snapshot with time string [20230620082521] and set cluster state as Maintenance
2023-06-20 08:25:25,842 Configurer[internalScheduler-11] INFO c.r.w.c.d.s.ClusterStateMachine - Change cluster state from In_Service to Maintenance
2023-06-20 08:25:25,842 Configurer[internalScheduler-11] INFO c.r.w.c.d.s.ClusterStateMachine - It is the leader, update the shared info from blade [Ruckus-LAB-SmartZone100] changes :
{ClusterState=Maintenance}
2023-06-20 08:25:25,843 Configurer[internalScheduler-11] INFO c.r.w.c.d.s.ClusterStateChangedHandler - Cluster state change : NewState [Maintenance]
2023-06-20 08:25:35,659 Configurer[internalScheduler-11] INFO c.r.w.c.o.ClusterBackupOperationService - <OPT> [Backup] all blade complete the snapshot, so set cluster state as In_Service
2023-06-20 08:25:35,659 Configurer[internalScheduler-11] INFO c.r.w.c.d.s.ClusterStateMachine - Change cluster state from Maintenance to In_Service
2023-06-20 08:25:35,660 Configurer[internalScheduler-11] INFO c.r.w.c.d.s.ClusterStateMachine - It is the leader, update the shared info from blade [Ruckus-LAB-SmartZone100] changes :
{ClusterState=In_Service}
2023-06-20 08:25:35,660 Configurer[internalScheduler-11] INFO c.r.w.c.d.s.ClusterStateChangedHandler - Cluster state change : NewState [In_Service]
Regards
Saurabh
Regards
Saurabh
