08-30-2023 05:13 AM
Hello! I have two Smart zone 104 controllers, they are in the same cluster. I needed to reset the first controller to factory settings, I turned off the controller, pressed the F/D button and turned it on, at first the status indicator flashed red, but after 10 seconds it started flashing green, after that the link on the port disappeared and is still flashing. I tried to connect via the console, when booting I was given that CentOS 7 was booting, after booting it asks me for localhost login, I tried all logins, but none came up. What should I do? So far, everything is working on the second Smartozne controller
08-30-2023 10:19 AM
Hi BLangley,
Could you please attach the Console logs when the Controller boots up?
Are you getting the login option when connected to the Controller via Console/SSH/GUI?
Additionally, you could try to Hard reset the device while the device is ON and we shall verify the boot logs.
08-31-2023 05:47 AM
Thanks for the quick response!
I can’t connect via ssh and gui, only console, because the link disappears when loading. It seems that this is a regular CentOS
I tried to reset to factory settings when the controller is turned on, but there is no reaction 😞
Several times I tried to insert the log here, but it is deleted after the publication of the post, so I post it here: https://docs.google.com/document/d/1M6LX6ggumFC4P7utL43JL4zrMJ9ukJy1u4QUnNqsmTU/edit?usp=sharing
08-31-2023 12:02 AM
I can’t connect via ssh and gui, because the link disappears when loading. It seems that this is a regular CentOS
08-31-2023 10:36 AM
Hi BLangley,
Thank you for your response.
I have verified the attached logs and it looks like the SZ 104 is not booting up properly.
Could you please confirm the below?
1. Before performing the F/D, what was the Controller version?
2. May I know why you have preferred F/D on the affected Controller? Has the Controller had any issues prior to F/D? like boot loop or powering up?
