Self-signed certificate for Web Authentication portal (vSZ 3.5)
dawid_krawczak
I would like to avoid a web browser invalid certificate warnings when I'm trying to authorize to wireless network through Web Auth portal. How can I correctly create and import self-signed certificate to my vSZ for Windows clients?
9 REPLIES 9
jakob_peterh_ns
Contributor II
Are you using the build-in Captive Portal, or a 3.th. party portal?
Anyway: A self-signed certificate will allways generate a warning.You need a proper officially signed certificate to not trigger those warnings..
dawid_krawczak
I'm using build-in portal and AD authorization.
The hostname/IP of the portal needs a valid certificate.
PS: You can never remove the warning, if the client asks for a secure site, and get's another secure site.
So, do I need to create and import valid certificate for each AP? The authorization portal  seems to be loaded from AP (it has APs IP)...
