Self Registration Guest Pass Generation in Smart Zone controller running in 6.1 version
Ambika-leimapok
Summary:
  • In this article, we will look into the steps involved in setting up Self Registration Guest Pass Generation in Smart Zone controller running in 6.1 version
Note: This feature is available  since 6.1 version onwards
Network Environment:
  • SmartZone/Virtual SmartZone [Essentials/High-Scale] (Controller), version 6.1.0.x.x
  • R710 (Access Point)
Setup Procedure:
  • To create SMTP server in the vSZ/SZ GUI, navigate to ‘System->External Services->SMTP’ and turn on the “Enable SMTP Server” toggle, fill the SMTP server details. In my example, I am using gmail server
  • Do the test, once it is successful, click on “OK”
  • Once the SMTP server has configured, create a “Guest Access Portal”, navigate to “Services & Profiles”-> “Hotspots & Portal” -> “Guess Access” then select the “Create”
  • Fill the details, turn on the “Self-registration” toggle and the “Guest Pass SMTP Server”
  • Post Guest Access Portal creation, create the WLAN for the Guest Access
  • Navigate to “Wireless LANs”-> Select the Zone then click on “Create”
  • Name the WLAN, in my setup I named it as ‘Test, Authentication Type as "Guest Access" and Method as "Open"
  • Encryption Options is selected as ‘None' (but it can change based on requirement).
  • Under Guest Access Portal, select ‘Guest
  • In 'Guest Portal Service’, select the Guest Access Portal profile which we have created from the drop down then click on “OK”
  • All other settings including VLAN assignment for end-user devices are set to the default values in my set up
Leimapokpam Ambika
Leimapokpam Ambika
Sr.Technical Support Engineer
CWNA | RASZA | RACPA
2 REPLIES 2
dk1089
Very helpful article.
Evandro
Hi Ambika, would this method be for a single use only? I ask because when the pass expires, it is not possible to generate a new one because the controller informs that the email already has a registration, and when using the option to resend the password, we receive the password by email with the access time information that appears to have been renewed, but when trying to log in I receive a warning that the pass has expired.
I couldn't load the prints here.
