12-02-2022 08:04 AM
Hi Guys,
Can I use module cisco GLC-LH-SMD plug into interface module fiber of WLC SZ144 10GB?
Any guidance appreciated.
02-14-2023 03:09 PM
Dear NonSok,
unfortunatelly SZ144 does only support SFP+ Modules and they need to be intel/brocade compatible. So you can make only 10Gbps connections on Fiber ports. 1Gbps connections can be only done from Cupper Ports.
Br,
Mark.
12-15-2025 09:52 PM - edited 12-15-2025 09:53 PM
hi mark, can you share the article/document where it is mentioned. ?
12-15-2025 11:57 PM
Dear hemant,
I tried myself and it did not work at the time when i have answered here. Also if you have access to the Intangi Iris tool you can check.
It will give you only the option for 10G SFPs to select and not 1G SFPs - (Checked today - with latest update)
Br,
Mark.
