12-29-2025 12:46 PM
I recently replaced a 2-unit ICX7750 switch stack with 2 7850s and the new stack is not completely syncing up with SmartZone (6.1.1). I assumed maybe there was a hostname or some kind of conflict with the original stack, so I deleted the 7750 stack from SmartZone, but it's been several days and the new stack has not changed. It shows the correct serial number, mac address, model, and firmware version, but it says the hostname is N/A and I can't see any stacking, health, traffic etc. information. So far from the switch side, I have removed and re-added the SZ manager config and used the "manager disable" command. I have not tried reloading the switch, I'd like to avoid that until absolutely necessary. I'm not sure what else to try, any suggestions?
01-20-2026 09:01 AM
Hi Modassir,
Thank you for responding! We ended up reloading the switch and it was able to connect to SmartZone.
01-20-2026 05:02 AM
Hi Sydney_N,
Please check the manager logs using the command "show manager log". This will give us some related information.
Regrads,
Modassir
01-20-2026 09:01 AM
Hi Modassir,
