08-22-2025 09:08 AM
08-24-2025 10:58 PM - edited 08-24-2025 10:59 PM
Hi HotelWifi,
Thank you for contacting Ruckus Support.
To allow a client to print while both the client and the printer are connected to the same SSID with client isolation enabled, please make sure the printer’s MAC and IP addresses are correctly added to the whitelist. Follow these steps to configure the client isolation whitelist:
Ensure that both the MAC and IP addresses of the printer are correctly entered. This will allow the client to communicate with the printer while maintaining isolation on the SSID.
Note: If the printer uses dynamic IP, consider assigning it a static IP to ensure reliable access through the isolation whitelist
Please let us know if you need any further assistance. You can also create a new case for further troubleshooting using the below link.
https://support.ruckuswireless.com/cases/new
Ashwin M
08-26-2025 05:06 AM
I was using only the MAC address, and that was not working. What is the difference between adding only the MAC address to the whitelist vs adding both MAC and IP? Can you explain this based on the layer 2 and 3 OSI model?
