02-22-2022 08:21 AM
Hi team,
How much blocked clients can i create on smartzone high scale ?
Atte.
02-23-2022 08:38 PM
Hello Roger,
The SZ-H documents do not do mention about the maximum amount of clients that you can block by selecting a client and then the option block.
Might you be referring to block clients using L2/L3 ACLs?
Kindly share some more details or whether there is any issue that is been faced.
02-24-2022 06:07 AM
Hi Orlando,
my question is about that feature:
Atte.
02-24-2022 10:14 AM - edited 02-24-2022 10:17 AM
Hey,
Thank you for clarifying.
For each client that we block, a new line will be created in the L2 filter. Each L2 filter supports a maximum of 128 lines.
Only one L2 filter can be applied per WLAN.
Please let me know if you have additional concerns.
02-25-2022 06:22 AM
Hello Orlando,
i was thinking that this ACL will not be applied to the WLAN in the same way as the L2 or L3 acl, instead, it seems that it will be applied by ZONE or AP, am I correct?
With regards,
