How do I get OIDs to obtain information from APs controlled by Virtual SmartZone 3.6.2?
cesar_murilo
I had downloaded the mibs from the link below, but I don't have the OIDs I want:
https://support.ruckuswireless.com/software/1869-smartzone-3-6-2-mr2-snmp-mibs-for-sz-100-and-vsz-e-...
 I wanted the OIDs to be inserted into Zabbix, for monitoring the connection status of the AP, the number of clients connected, and the CPU usage of the AP.
3 REPLIES 3
diego_garcia_de
Contributor III
I managed to get them into zabbix. You need to use the stand alone AP mibs and then maybe play around with a mib browser
See here https://support.ruckuswireless.com/so...
This is correct, use a MIB browser (or even snmpwalk) to find the needed OID.
Esteemed Contributor II
I found some advice in a KBA-3141: MIB files for Zabbix tool
--Since Zabbix  files do not  support MIB files, we need to convert the MIB files into XML format .
--We can convert  MIB files into XML format by using the link:http://www.snmpsource.com/snmp_mib_viewer.asp
--Once after converting we can upload the file into zabbix tool,which helps to monitor the network.
