DHCP on virtual smartzone, need to supply clients connecting to the guest SSID from dhcp on the controller
mohammad_shamse
Hi, please i need help regarding how to set DHCP on virtual smartzone. We need the clients of guest vlan to take ip from dhcp set on the controller, hopefully someone can guide me about how to set this. thank you
5 REPLIES 5
sanjay_kumar
Valued Contributor
Hi Mohammad,
Please find the below link and refer page number 403 "AP-based DHCP/NAT" section for the configuration. I hope this helps.
https://support.ruckuswireless.com/documents/2956-smartzone-5-1-2-administrator-guide-sz300-vsz-h/do...
mohammad_shamse
Thank you for your reply.
from the documentation it seems that we should deploy the enable dhcp for multiple APs setting.
But can you tell me where to set the default gateway ip address for the dhcp pool.
sanjay_kumar
Valued Contributor
Hi Mohammad,
The gateway will be the AP's IP, depending on the config option you choose. There are 3 options as below:
Enable on Each AP.
Eable on Multiple APs.
Enable on Hierarchical APs.
Check out the page number 404 for more information.
sanjay_kumar
Valued Contributor
