06-06-2024 05:10 PM
Hello I have an issue where half my network went dark. After looking into the matter it appears the wlan service broadcast 2.4 and 5 ghz check have been removed from from my h510 access points. They are being managed by a smartzone100. Everyone I try to re-enable them it acts like it’s saving the change but then when I look to check the device don’t take the config. I have tried factory resetting the aps and get the same result. All of the devices having the issue are showing online and are pingable at the up address which the sz has them listed as. When I try to log into the local gue to try to config the aps is says the wireless is disabled but it won’t let me make any changes assuming because it’s being managed by the sz. If anyone has any ideas or has experienced this before please help!
08-20-2025 01:05 AM
Hello Jboynton,
Thanks for reaching out.
After doing the factory reset of the AP do the join back to the SZ?
AP can be managed by the SZ only if it is SZ managed AP.
You can check from the CLI of the AP "get scg" it will provide information if it managed by the SZ or not.
Regarding the AP is not broadcasting you can check if the AP are mapped to the correct AP group and the waln are mapped to the correct group.
You can reach Ruckus tac as well if you need support for this.
Pranav Anand | Senior Technical Support Engineer
