The forum board you are trying to access is permanently deleted.
06-20-2022 01:02 AM
Could you tell me SZ124 can support R550 & T310d?
06-20-2022 06:57 PM
Hi @jackal
Yes the controller does support both model. FYI it is the firmware version compatibility with AP's and not the controller. The latest code 6.1 and 5.2.2 both supports R550 and T310D together.
https://support.ruckuswireless.com/documents/4058-smartzone-6-1-0-0-935-ga-release-notes
https://support.ruckuswireless.com/documents/4207-smartzone-5-2-2-lt-gd-mr-2-release-notes
Best Regards
Vineet
06-20-2022 04:32 PM - edited 06-20-2022 04:33 PM
Yes. Documentation
06-20-2022 06:57 PM
Hi @jackal
Best Regards
Vineet
10-19-2022 04:02 AM - edited 07-27-2024 07:52 PM
thanks for your answer I am using R550, so this helped a lot.
10-19-2022 05:12 AM
